When a Logic Block is triggered by a subtable row field—such as when updating a list lookup value—how can I directly access the specific row that initiated the trigger within the Logic Block?
Ian’s response is correct, however, as the help text in the screenshot says, this will only work for Subtables with a table type of Main. That checkbox does not work with Subtables of type Sub.
