What security role is required to export a CSV from an interactive report?
I am trying to export data from an interactive report I created, and am getting an error that I am not authorized. How can I find out what security role my user needs to be allowed to export?
Export access is granted at the permission level for the security group of the Table you are exporting.
Depending on your access level to those objects you would be able to identify the Permission Definition which grants access to that Security Group through the Permission Where Used Inquiry which will identify Duty Role Definitions which you can then search in Role Hierarchy Definitions to identify Functional Roles you may require.
If you do not have access to the above you may need to reach out to your System Administrator to aid in identification.
