Patch 14 (25.2.14) — Platform & Platform AI
High Value
- Project Builder: The New Project Builder Experience Delivers Smarter, Faster Builds and Fixes—Opt in to next generation agents that reason through their own part of your project, so apps build and get fixed with more accuracy and less back and forth.
- Project Builder: Build Webhook Endpoints to Capture Events From Other Systems—Ask Ed the Builder for a webhook and activate it from inside your project, with no manual Webhook Setup record or secret.
- Webhooks: Support More Vendors and Signing Methods—Connect webhooks to vendors that sign requests differently or send non-JSON data, and see why a request failed authentication.
- Project Builder: Automatic Checkpoints After Every Prompt—A checkpoint is created after every prompt, so you can undo or restore your work without saving one yourself.
- AI Model Version Setup: Configure Models by API Style and Capability—Choose how a model communicates and where it is hosted, and reuse one host connection across many models.
- Project Builder: Scan Barcodes with Your Phone Camera in AD Apps—Build AD apps that let users scan barcodes with their phone camera.
Notable
- AI Model Version Setup: Deprecate Sonnet 4.5 Models—All Platform Sonnet 4.5 model versions are deprecated. The fallback version stops working on 2026-11-30 and the primary version on 2027-03-31.
- Project Builder: Add Haptic Feedback to AD Apps on Mobile—Build AD apps that vibrate the device to confirm an action.
- Ed: Restart Conversations from any Point—Retry from a message instead of starting a new conversation when something goes wrong.
- Project Builder: Asks the Right Questions Before Building Your Integration—Ed the Builder asks clarifying questions when an integration request could go more than one way, and suggests a standard API when it fits better.
- Metadata Sharing: Include Role Hierarchies and Topic Relationships in Bundles—Move role hierarchies and doc topic relationships between environments.
- Message Definitions: Trigger Events Based on Email Status—Run logic as soon as an email is sent, delivered, bounced, or reported as a complaint.
- Integrations: New REST API Documentation Explorer—A cleaner, more user friendly viewer for Nextworld’s REST APIs.
- Project Builder: Fewer Unexpected Jumps and Scrolls While You Work—Project Builder and Ed the Builder conversations are less likely to pull you away from what you’re doing.
Bugs & Small Features
- At-Cost Consumption: Capture Every AI Call—Every AI call, including New Project Builder Experience turns, now records its token usage. You won’t see a change yet. Invoicing and the AI Consumption Inquiry use it starting in 25.2.15.
- Long-Lived Token Exchange: Enforce Token Guarantees on Exchanged Sessions—Sessions created from a long-lived access token follow the token’s security rules, and can’t reset passwords or create new tokens.
- Quick Import: Better Timeout Handling and Messaging—A quick import that exceeds the time limit stops cleanly and tells you how many rows were processed.
- Advanced Migration: Migrated Metadata Cache Management Improvement—Fixes inconsistent cache handling for migrated metadata objects (also patched to 25.2.13).
- Navigation: New Ways to Access REST API Documentation (Formerly Endpoint Documentation)—Reach REST API documentation through shortcuts and searchable menu entries.
- Navigation: New Menu Shortcuts for Help and Release Notes—Open help and release notes from the navigation menu search bar.
- Navigation: One Menu Entry for Approval & Notification Definitions
