Available-Hidden columns are locked
Available-Hidden columns are locked and unable to toggle on.
can somebody please suggest how to resolve this?
This happens when something such as a logic block or app setting is hiding that field on the list view.
Thanks for your reply Ian. There is a use case to default Column Order in Cash Receipts Detail Table. I have checked in app settings and didn’t find correct solution. If it is controlled by a logic block then there must be a specific reason for it I believe. However because of it the column order is not matching from the application builder and main menu.
Is there any way to unlock the column.
There is not a way to unlock it that I’m aware of.
