Delivered Data tables of type Main and Settings w/Subtables
Can Main and Settings tables with attached subtables be delivered in Delivered Data Definitions? Will the data be delivered from the subtable?
Yes, subtables can be on Delivered Data tables and they will be delivered, however, the Delivered Data Definition must be either unlocked or partially locked. If partially locked, the subtable itself cannot be locked. The fields on the subtable itself cannot be configured and all subtable records are delivered if the parent record is delivered.
