When configuring the delivered data records for a specific Delivered Data Definition (Table), is the Delivered Data Setup the only application available to select the records? Is there perhaps another application that allows one to select all records from a table and add it to the DeliveredDataAssignments table, or add records based on a filter? If not, will NextWorld have any objectsions if we created an application to make it easier to add many records to the DeliveredDataAssignments table?
As far as I know, Delivered Data Setup is the only application available for selecting which records to deliver. I am not personally against using scripts or supporting apps to feed it if you think that is more efficient. Can you provide an estimate of how many records some of these tables have that might want to be delivered that makes this worthwhile?
I’ve also located a pre-existing idea in the Nextworld backlog that makes this same ask and have linked this discussion to that idea.
