Is there a way to show-by-default platform delivered fields (ex: nwCreatedDate, nwLastModifiedDate) using Application Builder? I see these fields are populated automatically on Nextworld apps and can be displayed in the UI if I use the column selector to show these fields, but I am wondering if I can show these platform fields by default so that the user does not need to use the column selector?
If you add the platform delivered field to your table then it will show up as an available field on your app. Then you can apply display it by default and apply sorts to it like any other field.
