How do I configure my Guided Tour step to highlight “Edit”? I was able to configure so it would select the “Actions” (i.e. 3 dots) but have not been able to figure out “Edit”.
Hey Bethany! You can’t specifically highlight the Edit button in a Guided Tour. There are some limitations. You can’t highlight system buttons or other buttons found within form/row action menus. You can highlight an entire form action or row action region, though.
Supported elements include:
Button—For internal use only.
Custom—For internal use only.
Field—Enter the Data Item Name associated with the field.
Field Action—Enter the Data Item Name associated with the field.
Form Action—Enter “Actions.” (This highlights the entire form action menu)
Header—Identifies the app page header row. Use Chrome Developer Tools to locate the specific element name.
Page—Identifies a specific detail app page. Use Chrome Developer Tools to locate the page’s element ID.
Row—Enter the display name specified during configuration.
Row Action—Enter “Actions.” (This highlights the entire row action menu)
