Let’s say I have the 6 records in a table whose workflow statuses are:
DRAFT
ACTIVE
INACTIVE
INACTIVE
ACTIVE
ACTIVE
Is it possible to build an Info Box visualization for this showing DRAFT - 1 | ACTIVE - 3 | INACTIVE - 2 ?
DRAFT
ACTIVE
INACTIVE
INACTIVE
ACTIVE
ACTIVE
You should be able to achieve this using:
That is a bug (workflow fields aren’t listed in that main side bar because they can’t be used in form layouts but they can be used in visualizations). The work around is to:
