Most of the other apps I’ve seen that require lot assignment have lot assignment mini-apps that are used to designate which lots a given transaction is associated with. But the Product Completion app has no mini-app row action and I can only assign one lot on the detail line that is loaded in after entering my Work Order.
A lot needs to be defined once per product completion transaction detail. You can use the duplicate row or field actions to copy the information from the original line to a new line and that will allow you to define an additional lot with a specific transaction quantity.
