Is there a way to set the initial values or change increment variables
How can incremental fields that are either hidden or displayed on a screen be set initially or changed? Here is an example:
To reset the value of an autonumber, launch Automatic Number Values and adjust the Most Recent Number field.
To adjust the increment of an autonumber, launch Automatic Number Definitions and modify (or customize first then modify) the record and adjust the Increment field.
