Logic Block Field Action Removed
Hi there, I see the field action to open a logic block in the LB Builder is no longer offered in the list view and is only available via a row action? Confirming this is intended and/or whether it will it be returning again? Thank you.
@cj_fusch can you confirm?
I believe that with the 25.2 release, the field action to open Logic Block Builder is redundant because logic blocks always open in developer studio. Simply double-clicking the logic block from the list view will open it, as will the row action.
Thanks, @ross . Saw double clicking and row action worked. I just liked the field action when needing to open a LB quickly when browsing. Thank you for the feedback.
