MCP connection failing to authenticate? Check your Redirect URL configuration
If your MCP client can’t authenticate, or you’re seeing auth errors when trying to connect, the most common cause is a missing or misconfigured Redirect URL in your tenant setup.
Instructions can be found in the “Enable External MCP clients to connect to your environment” topic in the System Administrator section of Nextworld Help.
