We’ve enhanced the Explorer Pane within No-Code Studio to make it easier to access your most used object types.
- The Explorer Pane is now organized into two sections: Favorites and Categories.
- You can now filter by Object Type directly within the Explorer Pane, saving you time when you need to navigate to a specific object, or create a new object.
- Upon filtering for an object name, any object type that is opened in list form will persist that filter.
See release note RN-25.1.05-[Nextbot]-5497 for more information.
This feature became available in August, 2025 as part of release 25.1.05
