Operation sequence for phantom components
How is the operation sequence of the phantom components determined?
This will depend on the phantom type defined in the Item Org Master application for your phantom item. There are currently two values for this field: Phantom(Phantom Operation) or Phantom(Component Operation). Based on which is selected the operation sequence will either be inherited by the phantom or it will retain the operation sequence on the component.
