Subtable as Form Style - Force on Same Line
Hello,
Is there anyway to make it so that the UI look for a subtable in the form style so that everything on that subtable line is on the same row still so it doesn’t start new lines. Or is there any way to customize that look in general or have any control over it?
The lines are just a bit unnecessarily long so its creating a new line instead of just staying on the same one. I assume the order is just the order we place it in on the UI Detail Form View?
I believe the only control you have for form style suitables is to adjust how wide each of the fields are in their data item definition under display size.
Okay thank you I will play with that. Do we think there could be capability in the future to have more adjustment ability over that?
If you are a Nextworld customer or partner, you can work with your system administrator to submit an official enhancement request with customer support. Include a link to this post in the support ticket. If you’re not a Nextworld customer, keep an eye on release notes. We’re always making improvements.
My suggestion would be to introduce similar row/column layout support to what detail forms have.
