Turn off Visualization in GL Mapping Rules Application
Hi there,
Is there a way to turn off the visualization chart shown at the top of the GL Mapping Rules application permanently?
If I uncheck the List Lookup value when I go into GL Mapping Rules application, it hides the vizualization. If I edit a GL Mapping Rule and save and exit, when I return to GL Mapping Rules list view again, the visualization shows again.
Is there a way to just have it not show once I have unchecked the option in the visualization List Lookup?
I believe this is a regression; when I test in 25.1, the system remembers if you have previously disabled a visualization. In 25.2, it seems to forget.
@ian.p Must I log a ticket or are you fine to take it from here?
I already created an internal bug for this; if you want to track its progress and get updates on it, log a ticket. If not, no problem.
