Work Order Commitments
Why are my work order commitments not hard committing?
Check to see if your system is configured to hard commit.
  • Optionally setup Manufacturing Execution Module Settings (if you are committing via workflow.)
  • Manually commit from the work order workbench.
Then verify Commitment Level has been set to Hard on the work order. If it is still not hard committed, check your inventory. Material does not get hard committed unless it is available.
