Are GL Entry Types Delivered
Hi there,
Please can you confirm if the records in GLEntryTypes are delivered by Nextworld or if this is a manual setup in a new environment?
Thank you.
A predefined list of GLEntryTypes are delivered and maintained by Nextworld using a special table type of Core Tenant - Metadata + Sparse. The list can be added to tenant-by-tenant, but the Nextworld-owned-list cannot be modified. The Nextworld-owned list of records is populated by default for all new environments. There is a backlog idea about converting this table to be delivered and maintained using the Delivered Data toolset but as far as I know that work is not currently planned.
