Custom Barcodes
Are custom barcodes supported in Advanced Inventory? How do I set them up?
Yes, custom barcodes are supported in Advanced Inventory. To set up custom barcodes, navigate to the Barcode Maintenance application. Select the Barcode Type “Custom”. This barcode type allows you to create barcodes using a delimiter value as well as object prefixes, fixed or variable length positioning. In the Barcode Configuration section, standard objects can be configured for use in the barcode. Examples of these objects include item number, location, serial number, etc.
