Linking a Nextworld Inventory Location to an Advanced Inventory Location
How do I create a link between a Nextworld Inventory location and an Advanced Inventory Location so that the integration between the two can use it?
To create a link between a Nextworld Inventory Location and an Advanced Inventory Location, the nwId of the Nextworld Inventory Location must be stored on the nwExternalId field on the Advanced Inventory Location.
This field can be found in the List View of the Advanced Inventory Location to ensure that it was populated properly.
If the warehouse is defined as an Advanced Inventory and Nextworld controlled warehouse, the Advanced Inventory Location Setup application will show a field allowing you to select the Nextworld location to the Advanced Inventory location record. The application will save the Nextworld nwId to the nwExternalId field
