What are the different types of manufacturing definition types, and when should they be used?
I think you can find what you’re looking for in the documentation. Check out the topic “Definition Types - Discrete manufacturing” in Nextworld Help. It covers setup examples for 5 different setups of a Definition Type record that can be used to define the characteristics of the Product Definition, Bill of Material, and Routing and when those setups could be used.
