Can kit components be deleted?
If I add a kit to a Sales Order, can I get rid of a kit component if I don’t want it on there by deleting it like you can on regular line items that are at New status? Are there restrictions on what components can be deleted after you’ve added the kit to a Sales Order?
You should be able remove a kit component through the kit selection option so long as it is not a required component for the Kit’s Parent.
Currently using the row delete option is not supported for Kit Components on Sales Orders.
