Does Nextworld support an ETO process?
Yes. You can use the Definition Types application to create a definition type of engineer to order that can then be used on your work orders, BOMs, and routings to keep track of materials and time throughout the engineer to order process. You can view the help text documentation “Definition Types - Discrete Manufacturing” for an example setup of this kind of definition type.
