Workflow templates
In No-Code studio when building a new table/application, you get the option to select a basic workflow template. Great feature. But, if you don’t use the studio and do that on the first attempt, you don’t have the option to use a “template” workflow.
Is it possible to allow for custom workflow templates (both prebuilt out of the box and customer created) to be available to apply to a table after the table is created?
That would be a very usable feature.
I agree that would be convenient for existing Tables/Apps. We will add this to our list of enhancements we hope to provide in the future. Thanks!
